Sold/Expired Jeep Cart
BMan
Custom built (by mphudak on most boards) Jeep Cart for sale. Up for sale because we have to many toys and don't use this anymore.
Details:
- Made from the rear of a TJ (tub/frame)
- 3 Link coil suspension
- D35 Axle minus the ring gear
- New axle seals
- Uses a 2" ball
- Has GA trailer ID already so getting plates is easy
- I believe the cover is a Besttop
- 16" Aluminum wheels
- LT285/.75R16 (33's) BFG MT's with around 33% tread
- Color is Dark Green
- Bling Bling "gas" cap cover
- All 4 corners are made of plastic
- Only Con I know of is the pinion seal seeps if tongue not propped up to point Diff up. Since there is no ring gear the pinion doesn't spin so RTV could be used or simply put in a new seal.
- Located in Marietta GA
Looking to get $1000 OBO
Where is the cart located? If you could give me a call at (864) 710-1701
Marietta GA (I've edited the initial post to show that). I'll try to give you a buzz tomorrow sometime. I just got back from docs and I have a sinus infection and bronchitis so I'm not to coherent wit all the drugs they gave right now. :****: I should be a lot better tomorrow.
