Hardline Crawlers
May 24, 2018, 05:55:06 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Check out the Calendar for all upcoming rides and competitions.
   Home   Help Calendar Login Register
Pages: [1] 2 3   Go Down
  Print
Author Topic: Ultra 4 Buggy Built by S&N Fab/Essentially Offroad - SOLD  (Read 23286 times)
Matt O.
Administrator
Offline Offline
« on: June 01, 2011, 09:00:07 AM »
This buggy was originally built by S&N Fab for trail wheeling and WE Rock comps.  It was sold to Steven O’Neal and made it to Georgia for several years.  I bought it from Steven in May 2008 and it was exactly as S&N had built it (air shocks, low ride height/belly and minimal uptravel).  I went through the buggy to fix and replace weak links or parts that did not work well.  With the help of Essentially Offroad the car was modified and prepped for Ultra4 Racing.  The makeover included replacing/adding the following: motor, torque converter, steering system, rod ends, AL links, 2.5” coilovers, air bumps & mounts, bladder type fuel cell, GPS/communications gear, pumper, rear radiator/dual fans, front tubework, rear tire carrier, new dash, shock mounts, hi-lift mount, etc.
The buggy qualified 9th in the 2009 KOH LCQ and crossed the finish line in the big race about 30 minutes past the cutoff time.  I qualified for KOH 2011 at SMORR in 11th place and we DNF’d in KOH this past February.  We had moved up 20+ spots before breaking a motor mount that took us out of the race.  Buggy was a featured vehicle in Issue 28 (March/April) of CRAWL Magazine, which included KOH coverage and the WOD Blower Buggy on the cover.  The body took a beating at KOH and has since been redone by BlueTorch Fab and the broken motor mount as been repaired and strengthened.
It is 100% race ready and meets all Ultra4 tech requirements.  On the other hand, if you want a great trail rig, drop the spare tire, spares, hi-lift jack, and all the communications gear and have fun.  It is the best technical rock crawling rig I have ever been around and it loves vertical climbs.  With all the shock tuning with Bilstein we have gotten it pretty fast in the whoops also.  All the heavy fab work was done by either S&N Fab or Essentially Offroad.  I only performed minor fab and repair work myself.  It has a few dented tubes and rock rash here and there.  They may be fixable with a spreader/hi-lift; I have just never tried.  If nothing else a few new pieces of tube could be added, none of the dented tubes are significant.  I am very anal with maintenance and prep, so this buggy has been gone through multiple times.
I have a full spread sheet and all receipts for the modifications I have made.  I do not have to sell this rig; it can sit in my garage for as long as it needs to.  I have it listed because I hate seeing it sit in my basement and not get used.  I am looking for a more family friendly rig and DD, so if you have a 4-door JK in nice condition I could possibly do a partial trade with some cash on the buyers part.  Otherwise I only want cash and serious buyers that want a very nice rig that has been meticulously maintained.
If the buyer wants it race ready as it sits the price is $40,000 OBO.  If the buyer just wants a trail rig I can remove the GPS, radio, intercom, pumper, jack, etc. and reduce the price to $38,500.  Feel free to PM or email me at moverton1284@gmail.com
Chassis
S&N Fab Bravo #2
1.5 x .120 DOM  (Smaller DOM thrown in for non-essential tubes)
51.5” Wide at Cowl
107” WB
148” Overall Length
23” Belly Clearance
78” Track Width
74” Height
~3,600lbs (4,000lbs Race Ready)
Motor
2006 6.0 LQ4
GMPP Hot Cam w/ LS6 Springs
Kevko Gated Oil Pan
-6AN Flow-Thru Fuel Rails
Cone Air Filter
Custom Headers & Dynomax Race Bullet Muffler
Custom Dyno Tune by Hinson Motorsports (290 Rear Wheel HP)
PacificFab Wiring Harness
31x19” All Pro Radiator w/ Aluminum Shroud
Dual SPAL Electric Fans
Custom Accessory Drive (Fixed Tension)
Trans
TH400 Mild Build
PTC Converter
Reverse Manual Valve Body w/ Compression Braking
Art Carr Gated Shifter
Griffin Cooler w/ SPAL Fan
Transfer Case
Atlas II 4.3:1
32 Spline Outputs
1350 Yoke Front
1410 Yoke Rear
Front Axle
Dynatrac Pro Rock HP 60
4.56 R&P & Detroit Locker
Custom Length 35 Spline Superior Inners (Branik Machined)
Standard Chevy 35 Spline Superior Outers  (Branik Machined)
CTM Joints
Dynatrac Knuckles, High Steer Arms, Diff Cover & Drive Flanges
Chevy 3/4 Ton Disc Brakes
Complete Maintenance (New Seals, Ball Joints, Bearings, Grease, & Fluid) in January 2011
Rear Axle
Dynatrac Pro Rock HP 60, Semi-Float
4.56 R&P & ARB Air Locker
Superior SF Shafts
Dynatrac Diff Cover
GM Metric Big Bore Calipers
Complete Maintenance (Seals/Bearings Inspected, Grease & Fluid) in January 2011
Steering
1.5” 7075 Aluminum Tie Rod
PSC 2.5x8” SE Steering Ram (-6AN Fittings & Pressure Lines)
PSC N-Style Pump w/ Gen IV Remote Reservoir (-12AN Fittings & Lines)
PSC 11.3ci Orbital Valve (-6AN Fittings, -8AN to Cooler)
Howe Inline Steering Cooler (-8AN Fittings)
Suspension
Front – 14” 2.5 Bilstein 9100 Series Coilovers w/ ACV Remote Reservoirs
Blue Coil Springs, 150/225
4.5” Uptravel
PRP Limit Straps @ Front Corners
Rear – 17” 2.5 Bilstein 9100 Series Coilovers w/ Remote Reservoirs
Blue Coil Spring, 200/275 w/ All German Motorsports Rebuildable Spring Dividers
9” Uptravel
PRP Center Limit Strap
1.75” 7075 Branik Aluminum Lower Links, 7/8” RuffStuff Rod Ends
1.5” 7075 Branik Aluminum Upper Links, 3/4” RuffStuff Rod Ends
Shocks Tuned by Bilstein @ KOH 2011
Wheels/Tires
(5) 39” Red Label Krawlers (90% Tread, New in January 2011)
(5) 17” Black Raceline Monsters w/ Aluminum Ring, 6 Lug, 4.25” BS
Interior
Custom Aluminum Dash by Essentially Offroad
Auto Meter Ultra Lite Gauges (Mechanical Water Temp, Mechanical Oil Pressure, Voltage and Electric Tranny Temp)
Lowrance Elite 5m Baja GPS w/ External Antenna
Rugged Radios Intercom w/ (2) PTT Switches
Vertex Race Radio w/ Tab Mounted Antenna
Carling Switches, In-Cab Winch Control
Wilwood Pedal & Master Cylinder Assembly
Wilwood Proportioning Valve for Rear Brakes
CNC Dual Level Cutting Brakes Plumbed Into Rear Axle
Quick Release Grant Wheel & Passenger Side T-Handle w/ Grips
Beard Ultra SS Seats, Recovered by PRP
Crowe Harnesses with Pads (New in January 2010)
PRP Custom Window Nets
Joe's Racing Clamp-On Side View Mirrors
All Interior Panels 1/8” Aluminum sprayed with Rhino Lining
(2) 2.5lb Fire Extinguishers (Liquid Iron Industries Quick Release Mount)
Snap In Front Windshield (Jeep Soft Top Style Plastic)
Exterior/Misc
BTF 48” Fiberglass Hood/Grille, Custom Aluminum Cowl
.063 Polished Aluminum Skins
1/8” Aluminum Roof
Rear Speedway Engineering Sway Bar w/ Steel Arms
ARB Mini Compressor
Smittybuilt XRC8 Winch w/ 3/8” New Winchline.com Rope, Line Protector and Sling Hook
VisionX 8” Xmitter LED Light Bar
Grote Trilliant LED Rock Lights (2)
Grote LED Brake Lights & Rear Facing Amber (Clear Lens)
Jaz 22 Gallon Bladder Type Fuel Cell, Dual Walbro Pickups, 45-degree Fast Fill Valve & Remote Fill Kit
Walbro 255 Fuel Pump (-6AN Fittings & Line) w/ Quick Disconnect Wiring for quick changes
Mallory Canister Style 5 Micron Fuel Filter (-6AN Fittings)
PCI RaceAir Pumper, 150 CFM & Dual Outlets/Hoses
Hella Horn
48” Hi-Lift Jack
Optima Yellow Top Battery
Trans, Steering and Atlas Breathers all plumbed into a catch can in the front
Has a Washington Title & VIN that I never transferred
Spares
Full Front Axle Shafts, Bearings, & Seals
Full Rear Axle Shafts, Bearings, Studs, & Brakes
Front Driveshaft w/ Joints
Race Radio & Mag Mount Antenna for Chase Truck
7075 Upper Link w/ Heims
Spare Serpentine Belt Mounted to Chassis
Misc heims, u-joints, yokes, hoses, belts, pulleys, etc.
Full Build Gallery Here:
http://essentiallyoffroad.smugmug.com/VehicleBuilds/EOR-Racing-4462-Matt/7055629_U7N4h#1317030612_6jTR4r8
« Last Edit: July 27, 2011, 09:16:27 AM by John Galbreath Jr. » Logged
Matt O.
2007 JKU Rubicon on 35's
wngrog
Offline Offline
« Reply #1 on: June 01, 2011, 12:17:07 PM »
Damn that is a good price.  It should sell fast.  Everyone knows you don't cut corners.
You are going to love the JK but hate the POS 3.7 that "powers" it.
Logged
blacksheep10
Easyline Crawler
Offline Offline
XBJRA champ/ 555 and team Nasty codriver
« Reply #2 on: June 01, 2011, 12:27:09 PM »
Holy shit that thing looks good, my only gripe is the panels.   When you had it all black with silver tube, that was one of the most head turning "jeep" buggies out there.
Logged
Kelly Kaiser
Vertical Limits
913.731.3040
Liberals should pay in blood for what they have done and are doing to our once great nation
Team Nasty, the name says it all, now get your clothes off and grab a Keystone
Matt O.
Administrator
Offline Offline
« Reply #3 on: June 01, 2011, 12:27:22 PM »
Yeah I don't really have my mind set on anything yet, really want a family friendly DD.  I have to focus on my career as I have a big opportunity in front of me, and I also have two babies at home.  Life has changed a lot for me and I just don't have the time to ride/race.
Logged
Matt O.
CSMITH
Guest
« Reply #4 on: June 01, 2011, 09:18:06 PM »
this is a sweet looking ride , i've never seen it up close , but it looks like it will flat out get it.
hate to see you sale it , it'll make somebody a good rig.
Good luck with the sale.
Logged
B.DRAKE
Offline Offline
« Reply #5 on: June 01, 2011, 10:25:56 PM »
Very nice rig! Priced cheap too!! Good luck with the sale and your career advances! Double Thumbs
Logged
2014 Polaris Ranger 900 XP 15s and 31s
87 Yota SAS 5.29s locked Murrah Motorsports bumpers and sliders Racelines & 40s
InDaShop
Easyline Crawler
Offline Offline
Dont Tread On Me
« Reply #6 on: June 02, 2011, 04:12:24 AM »
and MattO drives like a grandma when racing so it was even babied on raceday!   Flip Off
Logged
I aint seen 'em, he's elusive, like a chupacabra!
Wyatt Pemberton, Houston, Texas
Matt O.
Administrator
Offline Offline
« Reply #7 on: June 02, 2011, 05:15:06 AM »
Thanks guys, if it doesn't sell I just wheel when I can.  Wanted to see if there was any interest since I can always replace in down the road when time frees up.
Logged
Matt O.
CHASMAN9
Just in town for supplies...
Hardline Crawler
Offline Offline
Hardline OG Administrator
« Reply #8 on: June 02, 2011, 06:04:37 AM »
Absolutely one of the more capable rigs out there.  I have ridden in this thing myself and can vouche for it's abilties and would love to own it myself.  Great price and parts list unlimited for sure.   thumb
Logged
Gregg Cary
Chelsea, Al
"Heart Attack Buggy"
Many thanks to my sponsors;
Dewey, Cheat em, and Howe
#barkequalstraction
Sosebee's off-road and Performance
RCV Performance Axles- Strongest axles on the Planet-www.rcvperformance.com
Jays Hydrographics- www.jayshydrographics.com
Team Yukon
Matt O.
Administrator
Offline Offline
« Reply #9 on: June 02, 2011, 06:18:07 AM »
Thanks Gregg, also if Gregg and I can fit in it comfortably then most anyone should be able to.  Grin
Interior is wide enough where you are not hittling elbows all day.  I am 6'3" and have decent leg room.  It is a little short on leg room, but it is not uncomfortable by any means.
Logged
Matt O.
CHASMAN9
Hardline Crawler
Offline Offline
« Reply #10 on: June 02, 2011, 06:27:09 AM »
Still think we should have attempted the waterfall at the top of everest, the one my hero (Matlock) was ready to go down.   Drool popcorn
Logged
Gregg Cary
Chelsea, Al
#barkequalstraction
Team Yukon
bigsilly
Easyline Crawler
Offline Offline
« Reply #11 on: June 02, 2011, 07:17:00 AM »
This rig is priced to move for sure.  Matt you have done a fantastic job of updating it and making it more capable.  I do not think there is another rig for sale that is worth the money as much as this one is.  Good luck with the sale.  Double Thumbs
Logged
Camco Rock Racing #4447
Jimmys4x4 car GONE
2008 C6 6spd GONE
2013 JK Rubicon GONE
Bones
Offline Offline
That Guy
WWW
« Reply #12 on: June 02, 2011, 07:40:46 AM »
Bullshit, I have a KOH proven Vitara for MUCH cheaper.  Flip Off
This rig is nice, real nice. Always like S&N's work.
Logged
Matt O.
Administrator
Offline Offline
« Reply #13 on: June 03, 2011, 12:12:57 PM »
BTT
Logged
Matt O.
Matt O.
Administrator
Offline Offline
« Reply #14 on: June 04, 2011, 07:39:02 AM »
Here is the youtube channel.  Bunch of In Car Videos from race and pre-running.  Also I have added all the vids MadRam11 has of my rig as favorites.
http://www.youtube.com/user/moverton1284
2011 KOH Start 01 - EOR Racing #4462 - Matt Overton/Jamie Marsh
MattO on Hells Revenge at Choccolocco
MattO on Little Jagger
MattO climbing Tub Rock at Spring Fling at GrayRock offroad park
MattO on Cream Puff in Harlan, offroad,
« Last Edit: June 04, 2011, 07:40:14 AM by Matt O. » Logged
Matt O.
Matt O.
Administrator
Offline Offline
« Reply #15 on: June 06, 2011, 11:28:36 AM »
More Pics.  As you can tell this rig has gone through many stages and looks.  When I got it it was a light green and setup with low belly and travel on air shocks.  The maroon color was in 2009, including KOH.  I went to black in 2010 and KOH '11.  It is now flat black using vinyl wrap and the sides are polished aluminum.  Got tired of having it re-painted.
« Last Edit: June 06, 2011, 11:46:15 AM by Matt O. » Logged
Matt O.
Matt O.
Administrator
Offline Offline
« Reply #16 on: June 13, 2011, 08:07:22 PM »
BTT
Logged
Matt O.
B Gillespie
Offline Offline
« Reply #17 on: June 13, 2011, 10:29:41 PM »
Very cool rig.
Logged
Matt O.
Administrator
Offline Offline
« Reply #18 on: June 19, 2011, 10:42:34 AM »
BTT. Buggy works really well, still sitting in my garage ready to go.
YouTube - ‪MattO on Tub Rock‬‏
YouTube - ‪MattO on Buzzards Roost at grayrock‬‏
YouTube - ‪MattO on Broke Foot at hawk Pride Offroad park‬‏
http://www.youtube.com/watch?feature=player_detailpage&v=4aTGRpeBpTg
YouTube - ‪MattO in Harlan‬‏
Logged
Matt O.
CSMITH
Guest
« Reply #19 on: June 19, 2011, 08:59:30 PM »
I really figured this rig would be sitting at O'neal Dodge by now  shit
Logged
Matt O.
Administrator
Offline Offline
« Reply #20 on: June 20, 2011, 06:04:54 AM »
I talked to Steven before I listed it, he has a full stable I think
Logged
Matt O.
B Gillespie
Offline Offline
« Reply #21 on: June 20, 2011, 08:23:29 AM »
Never stopped him before!  shit Booyang
Logged
Matt O.
Administrator
Offline Offline
« Reply #22 on: June 20, 2011, 08:34:24 AM »
I even tried to trade him for a JK and some boot!  He has some killer rigs that most people don't even know about.  The are way nice than mine  Drool
Logged
Matt O.
CSMITH
Guest
« Reply #23 on: June 20, 2011, 08:30:13 PM »
I'm gonna move this back up top so Daniel Dennis can look at it again.
Tell mama you need a little cabbage and go ahead and buy this thing.
there ain't a nicer one around
Logged
Matt O.
Administrator
Offline Offline
« Reply #24 on: June 20, 2011, 08:45:05 PM »
Love it.  He wants to go racing and this one can get it done Grin  Just pick up and go race, fully prepped and ready to rock
Logged
Matt O.
Pages: [1] 2 3   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines Valid XHTML 1.0! Valid CSS!
