jordan7118
- Joined
- Apr 20, 2010
- Messages
- 1,555
- Reaction score
- 4
Cutting up a few more 14 bolts soon.
Have ready for pickup:
Open to trades. Will help with delivery as best I can. Hubs will fit in a flat rate box. The other stuff will be a little more expensive to ship.
Located in Hot Springs, AR.
Call or text (8AM-10PM, please) - 501 two6two 80 18
- Jordan
Hubs - studs should be okay for reuse - they aren't pressed in if you want to discard - hubs are in good, usable condition - come with bearings and flange bolts
Spindles SOLD to Mark - can leave more tube on other spindles if desired - turning these on a lathe to add a chamfer for welding and to square them up
Shafts - from first gen 14 bolt - inside of flange to end of splines is 31 5/8" on short shaft, ~37.5" on the long shaft
Center section - 17.5" tube on one side, 13" on other - will come with yoke and pinion housing, but no pinion - can include pinion bearings if you'd like
- (2) pair of shafts from 1st gen axles - $35 / shaft, or $60 / pair
(1) pair of SRW hubs with bearings - $75 / pair
(1) pair of spindles w/ weld-on disc brake brackets (includes spindle hardware) - $100 / pair
(1) pair of spindles w/ spindle hardware - $75 - SOLD
(2) empty center housing w/ pinion housing and pinion support bearing (roller, not expensive-to-replace needle) - $100
(2) CUCV Detroit - $350 shipped - BOTH PENDING SALE
(2) 4.56 gears - $100 shipped / pair - SOLD, PENDING PICKUP
(2) 4.56+ open empty (no spiders) carriers - $75 plus shipping - SOLD, PENDING PICKUP
- Jordan
