Sold/Expired GM LS3 6.2 NEW CRATE ENGINES COMPLETE READY TO RUN INCLUDING NEW HARNESS & ECM
Toney, Al
We currently have 3 BRAND NEW and 100% COMPLETE GM crate LS3 "turn key" engines up for sale. These engines are 100% ready to drop in, just add oil, hook up the supplied new harness and ECM, install the fuel line & mass air flow sensor, and you are truly turn key ready. Below is the list of everything included in this package.
GM 6.2 LS3 intake including fuel injectors, rails, and drive by wire throttle body.
LS3 specific rectangular high flow cylinder heads providing 10:7-1 compression and 430 horsepower rating.
LS3 aluminum block and rotating assembly including flexplate for automatic applications.
We include the Corvette front accessory drive kits, including all brackets, power steering pump, alternator, and water pump.
We also include the new Holley 241-88 valve covers to clean up the cluttered OE coil pack bracket assy ($157.00)
These engines come with our brand new custom built "stand alone engine" harnesses that only require a simple 4 wire hookup. ($150 additional fee if you will be running a late model automatic transmission)
We also supply the ECM's which will be programmed to your specific needs.
Every sensor including the MAF is also included with the engine.
We are selling these complete setups for $9500.00. If anyone is interested in these engines bare, or setup a differently, just run it buy us.
We also stock complete fuel system kits, headers, swap mounts, virtually anything needed to finish up most LS swaps. We also offer custom dyno tuning on our new Mustang in ground dyno. We typically keep 10-20 used late model 6.0 LS based engines in stock. If there are any questions, please give us a call at the shop for our best prices on any of our parts, engines, and transmissions we keep in stock. We are located in Toney, Al, just 5 miles South of the Tennessee state line. Please give us a call for any type LSX needs or questions @ 256-929-4051.
