Sold/Expired 2005'-up FORD DANA 60 HI STEER KITS
FORDTECHGURU
Member
redding ,ca
weaver fab would like to introduce our 2005-up hi-steer kits for ford dana 60 axles.
1" thick steel arms
triple doweled and keyed to knuckle (carbon steel dowels)
ability to retain vacuum hublocks if needed
5 bolt attachment
clears 5.25" backspacing wheels!
retains stock linkage points
tested to 10,800 lbs force without failure!
we stock 2005-2008 and 2009-up knuckles for quick exchange.
single side kit $275 exchange
both sides $500 exchange
absolutely the finest available hi steer kit for your axle
contact us through the board or weaver_fab@yahoo.com
we also now have tie rod adapter bushings for our 05-up knuckles, they allow you to drop in a 4140 bushing into the stock odd ball passenger side tie rod hole to sleeve it back to 3/4" and also have 5/8" i.d. for those wanting to retain the stock linkage from knuckle to knuckle. $20 each, need 2 for the 3/4" ones, top and bottom.. check it out..
