Sold/Expired SOLD Jimmy's 4x4 Bloodline Podium BRAND NEW. SOLD
zebrajeep
Jimmy's 4x4 CNC Podium Bloodline finished October 2015
$83,000 (Build sheet is over $108,000)
PRICE LOWERED $80,000
7-25-16
Price drop.
$72,000 OBO
Located in Mena, AR
Race ready. Will pass ULTRA 4 with Fuel shut-off valves
Engine: GM LQ9 6.0, Added ZO6 Cam, B&D Harness and Computer, Camaro 8qt pan with IMPROVED RACING trap door kit.
K&N Air cleaner, OBX stainless Headers, Holley billet Fuel Pump,
Truck Brackets, 105amp Alternator new, Moroso 3qt accumulator, IR adapter
Transmission: TH400 HD
Race/HD Kit, Hi-Flow Filter, Steel Thrust washers, Torrington under low Planet, NP205 output OEM Non welded
Transgo Fwd Full Manual
Locking Dipstick
Converter TCS Billet 2200
Shifter; Winters gate
Transfercase: Atlas II 32 spline front and rear outputs
Axles: Torq 14T Front 35 spline RCVs, Rear 40 spline, Spools front and rear
17" Fuel wheels (5) with custom powder coat
TIRES: SET OF 5 NITTO "K" Spec Trail Grappler 40x13.50-17
Steering Psc Extreme series 2.75, full hyd kit, (TC/€šP€š) Pump
Fuel Cell€š'" #280-032-NF Poly tank enclosed in steel container
Jaz 32G race enclosed tank w/extra Injection fitting, NO FOAM
Walbro 4-corner pickup ball valve in tank
Wilwood MC and brakes with drilled rotors
WINCH
WARN VR8000-s W/syn winch rope Blue and Factor 55 flat link Blue
Window nets, KC Highlights, Fox 2.5" Res Coilovers with DSC adjuster, 14/16, PAC springs, PRP Limiting straps, LED light bar
20151023_181421_zpsdoi0chzt[1] by rmwc, on Flickr
Untitled by rmwc, on Flickr
23999001359_fc14e5ebc2_k by rmwc, on Flickr
Re: Jimmy's 4x4 Bloodline Podium BRAND NEW
best looking ford i have ever seen drool drool :dblthumb:
That mother ****er is clean
Beautiful rig, love me some jimmy's 4x4. Wanna trade?
Curious why no triples on the rig?
It's even nicer in person!! I have seen it and it's drool!!
Few more pics
This picture shows the difference in a spider 9 and these Torq 14t R&P. Massive and only loose 1/4" clearance under the diff! Did I mention the rear is 40 spline!!
http://youtu.be/3bIwp07enY8
All the best parts!
Chromoly rod ends, 0.75 upper, 1.25 lowers with stainless misalignment spacers
2" Fox bumps all 4 corners
7075 Alcoa links, 1.75" uppers, 2.5" lowers
1.125" 35 spline Curry sway bar
Derale dual pass transmission cooler
Derale 18" heat sink steering cooler
PRP 5 point harnesses with sewn in shoulder pads
Optima Red Top battery
KOH approved window nets with spring loaded hardware
Engine head mounts (along with 2 engine mounts, transmission mount and TC mount for a total of 6 driveline mounts)
KOH approved stainless rear window screen
Manual line lock for parking brake
onetoncrawler said:
belly clearance? overall height?
:smoke:
thanks
20" belly
76" roof
78" light bar guard
Interior is very clean!
It will be at Clayton OK this weekend if anyone wants a closer look.
What's next, Doc? Still have the BTF buggy with portals?
Yup. Doing an LS1 engine swap and rebuild on it as we speak. I might keep the Jimmy's and sell the BTF. Time will tell.
Damn I wish I lived near terrain like that!!!! Just a big ole playground of stuff to run over and climb!!! Badass clean rig too! drool drool
Finally got her out this weekend
By the way, that LQ9 6.0 with the ZO6 Cam is a bad boy! It has a lot more power than my 410hp LS1 from Turnkey Engines! Probably making about 450hp! When you romp the skinny pedal, it yanks your eye teeth out!
