Ackerman angle and steering questions
Jonesn
Piner, KY
I'm messing around with building automotive style steering for a radio flyer wagon. Read up on Ackerman angle some and tried to incorporate it into my design. I'm still having issues of the inside knuckle wanting to go over center at full lock. I've messed with the offset distance from the kingpin and it didn't seem to make much difference.
I know this steering won't make much difference if it is off some, but I mainly want to learn how to fix it if I had to when scaled up.
Maybe I'm being overly simplistic, but wouldn't steering stops on the "inside" wheel so you are limited how far that wheel will turn, solve your problem? I know I have them on my KP 60...
It's a ****in' little red wagon... they all do it. the only way to avoid it would be a major redesign, but at some point it is still going to happen. Any time two parallel tires are tied together by a straight rod it will always happen to some degree
Try the locations in the pic.
Re: Re: Ackerman angle and steering questions
1993toy said:
If you look at most, if not all vehicle steering; the tie rod points are offset outside of the pivot points.
Most vehicles have the tie rod on the front....
You're missing the point of Ackerman
Nope, I'm not...just trying to help him "improve" on his current setup.
Re: Re: Re: Ackerman angle and steering questions
Putting the tie rod connections out where you drew them would make it have negative Ackerman and would make the tires scrub real bad when turning instead of tracking properly.
I agree, my suggestion will change the Ackerman angle. By the way, my suggestion is slightly exaggerated to how far they should move.
Changing the tie rod points will not affect the scrub, his steering axis is straight up, not angled.
Re: Re: Re: Re: Ackerman angle and steering questions
Not scrub radius...
The whole point of Ackerman is that the left and right tires follow different arcs when turning. With positive (correct) Ackerman the tires will naturally turn/track better than no Ackerman or negative Ackerman.
If your outside tire turns tighter than your inside tire (negative Ackerman) then they are fighting each other and will scrub around the turn, rather than rolling smoothly
He's definitely got positive Ackerman, maybe just too much. I do think moving the tie rod ends a little further outboard would help. Still has a way to go before hitting negative or even neutral.
I don't understand what what he's saying about the knuckle going over center at full lock.
Even in the pics where the inside tire is turned to the frame, the steering isn't over center.
His Ackerman angle is perfect in his drawing... Changing it at all would be a mistake... His entire problem is that his wheels are allowed to turn too far.... Hence steering stops.
This x2
The geometry doesn't line up so it's definitely not perfect. The turn center should match a constant point throughout the turn. I think he needs to shorten his steering arms by roughly 20% and then lengthen his tie rod to match the new arm mounting position. Currently, it looks like his steering arms are close to 25% of the tie rod length. They need to be more around 18% of the tie rod length. Hypothetically if his tie rod is 25 inches, his steering arms should be 4.5 inches.
