Hardline Crawlers
May 24, 2018, 05:52:18 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Check out the Calendar for all upcoming rides and competitions.
   Home   Help Calendar Login Register
Pages: [1] 2   Go Down
  Print
Author Topic: COLEWORX "HIGHLIGHTER" FOR SALE!!! 40,ooo deal - SOLD  (Read 37568 times)
COLEWORX
Offline Offline
COLWORX PERIOD
« on: August 26, 2010, 02:54:12 PM »
FORSALE!!!! 1997 JEEP TJ CUSTOM COLWORX HIGHLIGHTER, builders personal rig since built in 2008.
A little bit about Highlighter, it was featured in CRAWL MAGAZINE in issue 15 the summer of 2008 with a 3 page spread.   This rig was also in an episode of Powerblock TV called "Rocking Rock Racer".  This rig is exceptionally well thought out and built.  Bryan is 6'2" so naturally the rig has plenty of headroom, has opening doors, and full windsheild frame with glass if you want to run it on the rig.  It has headlights, led taillights and also a compartment built in for a tag on rear.  Rig was used as a hardcore trail rig, was drove to numerous trails on the road, it is really road worthy should you have to be on the road to get to the trails.  Truck has placed in numerous local rock racing events.  Not interested in any trades, Price is 40,000  Over $95,000 invested.  This truck needs no work, has been well maintained and is ready to wheel upon pickup.
CONTACT BRYAN COLE @ (931) 982-3401, OR AT COLEWORX @ (615) 599-0502.  THANKS! thumb
Specs. For Coleworx Hightlighter
Owner:  Bryan Cole
Hometown:  Columbia TN
Vehicle Type:  1997 Jeep TJ
CHASSIS
Frame/Chassis Design         Custom Coleworx Design
Frame/Chassis Materials      1 7/8-inch DOM
Overall Wheelbase         115 inches
Overall Length         158 inches
Overall Height            72 inches
Overall Weight         4000 pounds
Belly Pan Clearance         21 inches
Wheel Track Width         90 inches
DRIVETRAIN
Front Suspension/Type/Materials   4-Link with 1.25-inch heims
               2-inch 7075 aluminum DOM
Front Sway Bar         Currie Anti-Rock
Front Shocks            2.0 Fox w/ remote reservoir coilovers
Front Bump Stops         Fox 2.0
Front Axle Housing         14 bolt w 300m   axles
Front Differential/Locker      Detroit
Front Ring and Pinion/Ratio      4.56
Front Differential Cover      Coleworx
Front Axle Shafts         RCV Performance hardened 300-M
Front U-Joints            RCV Bell
Front Drive Flanges         Polyperformance Chromoly
Front Brakes            Wilwood Dynalite
Front Steering Setup         KRC full hydro with Eagle Machine
               Hexagonal single-ended ram
Front Drive Shaft         High Angle Driveline, 1410 joints
Rear Suspension/Type/Materials   4-link with 1.25-inch heims
Rear Sway Bar         Currie Anti-Rock
Rear Shocks            2.0 Fox with remote reservoir coilovers
Rear Bump Stops         Fox 2.0
Rear Axle Housing          Corporate 14 full floater
Rear Differential/Locker      Full spool
Rear Ring and Pinion/Ratio      4.56
Rear Differential Cover      Coleworx
Rear Axle Shafts         Ouverson Engineering 300-M axle with Custom                  300-M drive flange with aluminum cover
Rear Brakes            Wilwood Dynalite
Tire Make/Size         New, just released 43x14x17 TSL SX STICKY
Wheel Make/Size         17x9 Aluminum Raceline with custom
               Coleworx polished rock rings
Wheel Bolt Pattern         GM 8-lug
POWERTRAIN
Engine Make            GM Ramjet
Engine Displacement         502
Engine Torque            565
Engine HP            510
Engine Induction         GM Ramjet fuel injection
Engine Modifications         Stock
Batteries            Optima
Radiator/Fans            Be Cool twin fan setup
Air Intake            K&N
Exhaust            Custom 3 ½ -inch chrome plated
Transmission Make         PTC  TH 400 with reverse manual valve body
               Nitrous converter with 2200 stall and Durrelle
               Super Trans. Cooler
Transmission Shifter         TCI custom gated, no cable
Transfer Case            Atlas 4.3 with custom HD 300-M output shaft
Fuel Containment         Custom fuel cell with in-tank pump
BODY/INTERIOR
Body/Body Panels         â€™97 Jeep TJ
Body Modifications         Cut, chopped, and channeled
Skid Plate/Material         6061 aluminum
Painter Name            J.P. Patterson
Hood/Grill            Jeep TJ
Floors/Firewalls         Custom
Dash/Gauges/Switches      Carbon Fiber Autometer
Steering Column/Wheel      Grant
Pedal Assembly/Cutting Brakes   Wilwood dual pedal assembly
Seats/Harnesses         Corbeau GT 40 with Simpson Racing Harnessess
Winch Front            Warn 9.0 RC
[attachment deleted by admin]
« Last Edit: November 06, 2011, 07:39:03 PM by John Galbreath Jr. » Logged
COLEWORX
F.T.O
Offline Offline
« Reply #1 on: August 26, 2010, 04:04:45 PM »
SHE STILL LOOK'S BRAND NEW. THE TIRE'S & WHEEL'S LOOK REAL GOOD.
THE BEADLOCK RING'S ARE SICK.  I NO FOR A FACT IT WILL TAKE A BEAT DOWN.
HATE TO SEE IT GO. MAYBE A HATER WILL BUY IT. Flash em
« Last Edit: August 26, 2010, 04:17:46 PM by F.T.O » Logged
taterman
Offline Offline
« Reply #2 on: August 26, 2010, 04:53:31 PM »
 Smiley i love this rig
Logged
Hotrod
Guest
« Reply #3 on: August 27, 2010, 03:34:54 AM »
This buggy is an icon to our sport. Good luck on the sale. Now hurry up with the new rigs so we can all ride!
Logged
gdf
Offline Offline
ROLL TIDE
« Reply #4 on: August 27, 2010, 06:12:30 AM »
 Drool Drool Drool Drool Drool Hit It
Logged
Gared Flanagan
EB Customs ..... The fabrication genius
Custom Tint & OffRoad...the one stop offroad shop
Wide Open Design.... The only way is Wide Open
Image Offroad Photography
JohnG
Administrator
Hardline Crawler
Offline Offline
38 Special & Solo Buggy
« Reply #5 on: August 27, 2010, 11:27:29 AM »
This is a FOR SALE thread.  See General Discussion for spinoff thread.
Logged
Retired: I wake up in the morning with nothing to do and I go to bed at night with only half of it done!
CSMITH
Guest
« Reply #6 on: August 27, 2010, 09:30:03 PM »
this is an awesome rig.  I would love to have it myself.....good luck with the sale
Logged
B.DRAKE
Offline Offline
« Reply #7 on: August 28, 2010, 01:09:50 AM »
I would like to see you own this thing too! Go on and pay the man we know you gotz da moneys to make it happen :afro: Woot
Logged
2014 Polaris Ranger 900 XP 15s and 31s
87 Yota SAS 5.29s locked Murrah Motorsports bumpers and sliders Racelines & 40s
jtreeves1
Offline Offline
why are you taking the time to read this retard
« Reply #8 on: September 16, 2010, 04:11:50 PM »
sold yet?
if not free bump
Logged
justin tyler reeves
cj 7  LT1 with a little tweck
groved 44 boggers with locked 14 bolt and 60
all the goodies
4 link front coil overs with air bumb stops
4 link rear coilovers
lowkey
Guest
« Reply #9 on: January 20, 2011, 09:22:48 AM »
I wish I could get somebody to biuld me a buggy like this!!!! HHHHHHHHMMMMMM. shit
Logged
oldmanphillips
Offline Offline
Ole Yeller Turd Hauler
« Reply #10 on: January 20, 2011, 04:22:35 PM »
free bump
Logged
COLEWORX ROCK RACING FACTORY
onetoncrawler
Easyline Crawler
Offline Offline
« Reply #11 on: January 20, 2011, 04:27:47 PM »
free bump
good to see you here Double Thumbs
Logged
Daniel
JRPhillips
Offline Offline
« Reply #12 on: January 20, 2011, 04:29:07 PM »
oldmanphillips is right [[old]]
Logged
COLEWORX
Offline Offline
COLWORX PERIOD
« Reply #13 on: January 20, 2011, 04:35:45 PM »
in process of installing  14 bolt ft   at no extra  charge
Logged
COLEWORX
onealdodge
Offline Offline
« Reply #14 on: January 20, 2011, 10:46:24 PM »
1 good looking buggy.
Logged
COLEWORX
Offline Offline
COLWORX PERIOD
« Reply #15 on: February 16, 2011, 07:03:23 PM »
BUGGY  HAS  NEW  14  BOLT   FRONT   NEW   RCVS   ALL  NEW   JUST  ABOUT   BULLIT  PROOF   NOW   PRICE  STILL  SAME
Logged
COLEWORX
COLEWORX
Offline Offline
COLWORX PERIOD
« Reply #16 on: February 18, 2011, 01:06:13 PM »
 Cool Cool
Logged
COLEWORX
Roy_Hobbs
Offline Offline
« Reply #17 on: April 26, 2011, 09:59:23 AM »
Still for sale?  What ya asking now?
Logged
sledneck
Offline Offline
« Reply #18 on: April 27, 2011, 06:21:39 AM »
It says he asking 55K.  As soon as I hit the lotto its mine.
Logged
TURNEROFFROAD
Offline Offline
WWW
« Reply #19 on: May 17, 2011, 06:39:07 AM »
Bump if it needs bumping...
Logged
You can't beat the house...
Freedom of speech is fine unless you talk about the people with pull
COLEWORX
Offline Offline
COLWORX PERIOD
« Reply #20 on: October 28, 2011, 09:38:41 AM »
starting  new  build  ,   would  like  to  sell  . nasty   tough  with   the  new   frontend  and   500hp perfect  balance of  parts  and  power
Logged
COLEWORX
kmcminn
Offline Offline
« Reply #21 on: October 28, 2011, 12:00:21 PM »
Details of the new build?     Eat
Logged
Maybe next week.
CSMITH
Guest
« Reply #22 on: October 28, 2011, 03:52:44 PM »
 Fishing  I wish i wasn't broke
bump for a tough rig
Logged
jtrogers83
Offline Offline
WWW
« Reply #23 on: October 28, 2011, 06:18:32 PM »
damn fatboy come on you could afford this if you would quit being a trans killer  shit
i think you got a few mayo jars full of $100s left behind a chicken house
Logged
CSMITH
Guest
« Reply #24 on: October 28, 2011, 08:09:27 PM »
since i just sold BLUE BALLS..... Maybe i can do something about this lil rig here
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines Valid XHTML 1.0! Valid CSS!
