My new Heep.
the4x4pig
Gig Harborish
Selling the 06 LJ Rubicon because I found a deal I couldn’t pass up.
04 LJ.
6 liter LS
4l60e
Dynatrac prorock 60’s, 5.38’s, arb’s, full float rear
Atlas 4 speed.
Only 1500 miles on the build. Still lots of loose ends to tie up but it’s got the right parts.
Went to the dunes in Florance, OR back in April. First time in the dunes. Other than wishing I had more power, jeep did great, considering it wasn't built for that environment.
Thank you
Yes, still 4.0 and auto. Running 4.88s/ARBs and 37s. Axles are G2 HP 44/F and 8.8/R. Swapped them with a TJ I had. I knew these axles and what had been done to them. I didn't know the rubi stock axles and what had or hadn't been done to them. I need to re-gear, though. But due to limitations on the 8.8, I believe I can only go up to 5.13s. 5.38 is really the sweet spot from what I've read when running 37s and the stock auto for the street. Thankfully the Rubi t/case makes up for it on the trails for the most part.
I'm running 5.38's in my stock ruby 44's with 35's. Auto as well. Not sure I'd want to go much higher. That overdrive in our junk trans is just silly.
