Sold/Expired 4 seat CJ crawler with 24' hauler and sleeper.
Danimal
land o lakes, FL
4 seater CJ crawler with title and 24' hauler with sleeper (Tampa, FL)
This is not a trailer queen, it has been wheeled and has its share of rock scars. It's a tuff rig that will get the job done.
10,500 for rig. 2500 for trailerCall or text 727-505-2638
84 CJ7 with title
115" wb, 79" top of cage, 20" belly
CCOR built cage and tubework
96' corvette LT1 fuel injected with headers, 40 series flowmasters, and K&N cold intake
NP205 T-case
SM 465 trans with centerforce clutch and hand throttle
Front axle
Chevy Dana 60
5.13s
Detroit
35 spline inner/outer 4340 shafts
Spicer joints
Poly perf drive slugs
Stage 8 locking spindle nuts
BTF kryptonite cover
Custom truss with PSC double ended ram (full hydro steering)
Rear axle
14 bolt ff rear
5.13
Spool
31 spline shafts
Disc brake conversion
Custom truss
Other:
44x15" TSL's aetna cut in rear, uncut front
Eaton 32 bolt beadlocks with self centering rings
RCI 2161a fuel cell with straps
14" fox coilovers front/FOA 14" coilovers rear
Double triangulated 4 link front and rear with 1 ¼" lower and 7/8" upper heims
Links are 2" .250 wall dom
Corbeau Baja SS suspension seats front and matching rear bench
RCI 5 point harnesses front
Corbeau 5 point harnesses in rear
Optima yellow top battery with BTF battery box
Warn powerplant winch (air compressor) with new synthetic line and new controller
D rings front and rear
Sunpro oil, water, and volt gauges
LED tailights
Poly performance limit straps front/rear
Trailer (16' deck with 8' sleeper)
Trailer is a 24' enclosed that I cut down into a "toy-hauler".
It has two 3500lb axles with brakes on both axles
Brand new 15" tires E rated
Sleeping qtrs area has been started but not fully finished. All walls are steel studs and walls have been insulated. I have Two RV windows, kitchen cabinets, a futon, and work counter/flip up table that come with the trailer to help finish the inside.
interested in any trades?
Mustang – Street Legal Drag Car 1994
Front
Ground Pounder K member
Lakewood 90/10 drag struts
Rear
Adjustable Coilovers
Double Adjustable upper Control Arms
Weight Jacker adjustable Lower Control Arms
8.8 housing with c-clip eliminator
31 Spline Moser Axles
4.56 Gears (New)
Spool
50/50 Drag Shocks
Chassis
Sub Frame connectors
6 point cage
Motor
432ci Windsor
Hawk Racing 4.170 Stroke Crank
Eagle 6.300 Rods
J&E/SRP Pistons for a 347 Stroker with Yates Heads
Solid Flat Tappet Cam (Specs on cam sheet)
Double Roller Timing Chain
Heads- 1973 351 Cleveland 4v Heads (Bowl Blended)
Comp Cams 1.73 Roller Rockers
Intake- 2961 Edelbrock
Carb- Biggs Performance 950cfm Holly
Aeromotive Fuel Regulator
Black Holley Fuel pump with 1/2in line
12 gallon Fuel Cell
MSD Distributor
6AL Box 2 step rev limiter
Aluminum Radiator
Electric Fan
Electric Water Pump
Transmission
Power Glide (Fresh Aug 2012)
Converter- TCI worked by PTC with all new internals and front cover – Spragless (Fresh Aug 2012)
JW Bell-bell housing (New Aug 2012)
PTC Pro tree Valve Body(New not installed, ATI is still in the car)
Tires and Wheels
Centerline Wheels
Skinny runners on the front
26in Slicks on the Rear (New Aug 2012)
Cam Specs and Dyno Sheet are included on another sheet.
$14,500
Call: Mike Page 931-797-6676
Only trades I'm interested in are a 5th wheel toy hauler or a rzr xp, but thanks. Mustang looks sweet.
Thanks for the props Addison. hows the buggy build's coming along?? I decieded to sell for now and I'm going to go with a side by side for a while and a 5th wheel toy hauler to switch things up. I put alot of time in this rig and converting the enclosed trailer and only went on a few rides. Its ready to wheel!
few action shots..
I wheeled with you ad your wife at hale mt. Fr the feb. Jam. I was driving the white and blue jeep with thenoisy motor. You done good in your jeep. Why you getting out?
Hey Hal, good to hear from ya! We had a great time up there. Hopefully you got your steering issue fixed on your rig? That is one hell of a jeep you got there.. IT was crazy watching you rear steer through all those tight trees that Steve was putting you through. Anyways, I've decieded to join the masses and try out a RZR xp for a while. Were going to go with a Raptor 5th wheel toy hauler as well (or something similar). Just something different. I'm sure I will get back into a rig at some point. Text me sometime.. 727 505 2638
Great deal for a family friendly. wish i had my buggy sold and enough cash for rig and trailer. Nice setup
There is a sale pending funds on monday. If anything falls through i will repost and keep this updated.
