Sold/Expired Custom Tube Chassis Buggy, REDUCED Price
chaos78
Active Member
FORSALE!!!! Custom Off Road Buggy, Not interested in any trades, Price is $45,000. OBO Ready To Wheel, Not Even 6 Months Old
Contact Joe (615) 238-5234
Frame/Chassis Design Custom
Frame/Chassis Materials 1 3/4-inch DOM
Overall Wheelbase 116.00"
Overall Length 157.00" (Front Of Front Tire, To Rear Of Rear Tire)
Overall Height 77.00" (Highest Point Of Roof, Light Bar Folds Down)
Belly Pan Clearance 23.50"
DRIVETRAIN
Front Suspension/Type/Materials 4-Link with 1.25-inch heims
Front Shocks 2.0 Fox w/ remote reservoir coilovers, 2.0 fox Bypass Shocks
Front Bump Stops Fox 2.0
Front Axle Housing Spidertrax 9", Spidertrax Knuckles, TruHi9 3rd Member
Front Differential/Locker Detroit
Front Ring and Pinion/Ratio 5.40
Front Axle Shafts Spidertrax 4340
Front U-Joints CTM
Front Drive Flanges Spidertrax
Front Brakes Spidertrax Rotor, Wilwood Dynalite
Front Steering Setup KRC Pump, PSC Double Ended Ram
Front Drive Shaft High Angle Driveline, 1350
Rear Suspension/Type/Materials 4-link with 1.25-inch heims
Rear Sway Bar Currie Anti-Rock
Rear Shocks 2.0 Fox with remote reservoir coilovers, 2.0 Fox Bypass
Rear Bump Stops Fox 2.0
Rear Axle Housing Spidertrax 9'
Rear Differential/Locker Detroit
Rear Ring and Pinion/Ratio 5.40
Rear Axle Shafts Spidertrax
Rear Brakes Spidertrax Rotors, Wilwood Dynalite
Tire Make/Size 43x14.50x17 TSL SX
Wheel Make/Size 17x9 Black Spyderlock Wheels, Polished Rings
POWERTRAIN
Engine Make New LQ9 6.0L, Comp Cam, Crane Adjustable Rockers. Holley HP Fuel Injection, Edelbrock Intake, Elbow, And Throttle Body
Radiator/Fans Griffin Radiator And Dual Fans, SPAL Fan Controller
Air Intake K&N
Exhaust Custom 1 3/4" Headers, 3 1/2 Exhaust, Magniflow Mufflers. All Nitro Coated
Transmission Make New Custom TH 400 with reverse manual valve body, 3000 Stall
Transmission Shifter Sidewinder
Transfer Case Atlas 2 Speed
Fuel Containment Areomotive Stealth Fuel Cell
BODY/INTERIOR
Body/Body Panels Custom Aluminum Panels, Vinyl Wrapped (Flat Black), Lizzard Skin Coating On Inside Of Panels
Skid Plate/Material 1/2" Aluminum
Floors/Firewalls Custom
Dash/Gauges/Switches RacePak Street UDX Dash, 12 volt Guy Switch Panel, Lowrance Baja5 GPS, ADJ Light Bar
Steering Column/Wheel Grant
Pedal Assembly Wilwood dual pedal assembly
Seats/Harnesses Kirkey Aluminum Intermediate Road Race Seats With Covers
Communication Rugged Radios CB, Intercom, Cables And Headsets
Cooling Dual Parker Pumper Helment Coolers
Winch Front Warn 9.0 RC
Re: Custom Tube Chassis Buggy
Sweet buggy....if I had half of nealcj8s money I'd be coming to get it....free bump for ya
Specs on your light bar? Can it be bought somewhere?
Bump great guy to deal with thanks for the tires
reduced price. 49,500 obo
need to sell
bump for one of the baddest buggys on hardline if i had the coin i would be mowing **** down in that thing right now booyang
So you went up 4500 on the price.
Sent from my SAMSUNG-SM-N900A using Tapatalk
