onetoncrawler
Mo named it and I found it catchy so it stuck ;D
going to be a simple build, nothing flashy, but I figured it would be something out of the ordinary on here and maybe someone would like to see it
Specs
1.3 - Low Range pullies, header, power steering and GM alternator on propane
6.5 - 1 Samurai T-case
5 spd trans
Trailtough motor mounts, trans mount and mighty kong t-case mount with aluminum spacers
Front axle - Dana 60, 5.38 gears, spool, high steer, Barnes 4wd diff cover, yukon 35spl chromoly outers
using TMR 3/4 ton disc brake kit to save some weight
Rear axle - shaved 14 bolt, 5.38 gears, barnes 4wd diff cover and 3/4 ton disc brake brackets
4 link front and rear with Fox 14" coilovers and PAC racing springs
HeMan Machine Aluminum Links
Raceline Monster beadlocks with the most important piece of the build ---- 39 Krawlers
will post progress below
Specs
5 spd trans
