khite100
"Parting OUT Everything Must GO"
I have a custom built tube buggy. I am the only owner because I built this rig about 3 years ago for Dirt Riot Endurance Racing. I won the Southeast Championship with this car and many other finishes. I am only selling because I am looking at changing into another form of racing. This has been an excellent car and its ready to go. I just added the triple bypass shocks for the Championship in Texas back in October 2014. They were tuned by Fox's Wayne Isralean. Yes, it is a little dirty in the pics. Hadn't washed it yet.
Please serious inquiries only.
770-713-0170
• Custom 1.75" DOM tubing cage - SOLD
o Connection points to remove all parts
• Newly updated Chevy LQ4 6.0 - SOLD
o Freshly built LS6 243 heads - SOLD
o Competition Cams 54-444-11 XFIXE-R XER273HR-14 Camshaft for LS Gen III/IV, Three-Bolt - SOLD
o Competition Cams 26926-16 Dual Valve Springs - SOLD
o Competition Cams Retainers - SOLD
o GM Performance high performance head gaskets - SOLD
o Adjustable timing chain - SOLD
o Melling 10296 Oil Pump selectable high volume/high pressure -- I selected high volume - SOLD
o LS1 oil pan - SOLD
o 32lb Bosch high performance injectors - SOLD
o Moroso Oil Accumulator - SOLD
o Magnaflow Exhaust - SOLD
o K&N air filter with K&N pre-filter - SOLD
o Lokar Dip stick - SOLD
o Hydroboost Brakes - SOLD
• Fresh TH400 Built - SOLD
o Completely Rebuilt - SOLD
o Competition Shift Kit - SOLD
o Roller Bearing output upgrade - SOLD
o Sprag Upgrade - SOLD
o New B&M Vacuum Modulato - SOLDr - SOLD
o New B&M Stall Converter - SOLD
o New TCI Front Pump - SOLD
o New TCI Flex Plate - SOLD
o Derail transmission cooling radiator with electric fan - $125 - Sold
o B&M cooling radiator in series with the derail for additional cooling- $60 - Sold
o B&M 81040 Magnum Grip Pro Stick Shifter - SOLD
o B&M 80834 Super Duty Race Shifter Cable - SOLD
o Lokar dip stick - SOLD
• Griffin Radiator for LS engines with double Spal Fans - SOLD
• Atlas 4.3 2 speed transfer case - SOLD
o 1350 outputs - SOLD
o Passenger side drop
o Cable shifters for infinite position ability - SOLD
o Atlas support ring for rigid strength - SOLD
• Full Hydraulic Steering
o PSC Pump - SOLD
o TrailGear Double-Ended Ram
o PSC Reservoir with built-in filter - SOLD
o PSC Tilt column with quick release steering wheel - SOLD
o Derail power steering cooling radiator with electric fan - SOLD
• Axles
o Front Dana 60 fully built 4.88 Gears - $3735
• Chromo Axle Shafts
• Nitro Chromo U-joints
• Detroit Locker
• Reid Knuckles
• High Steer Arms
• Chromo Drive Flanges
• Fully trussed
• Heavy Duty Diff cover
o Rear Newly Built 14 Bolt 4.88 Gears - $1300
• Artec Industries Truss System w/ diff cover and yoke protection
• Detroit Locker
• Disc Break conversion
• Front and Rear 4 Link Suspension
o 1.5" 7075 Aluminum Upper Links - SOLD
o 2" 7075 Aluminum Lower Links - SOLD
o Chromoly Heim joints
• Suspension
o Fox 2.0 coilovers completely rebuilt and revalved for use as coil carriers with the addition of the triple bypass shocks. - SOLD
o New PAC Springs all the way around - SOLD
o Brand New Fox 2.5 Triple Bypass Shocks on all four corners - $3600 - SOLD
o Tuned by the Guru of shocks -- Wayne Isralean at Alltech Motorsports!!!!
o Fox 2.0 Air Bumps on all four corners completely rebuilt - SOLD
• Wheels - $2400 Package - SOLD
o Almost New BFG 39" Red labels - $1900 - SOLD
o Allied Beadlocks - $600 - SOLD
• RCI 22 gallon Fuel Cell - SOLD
• Front and Rear 1350 Carolina Driveline Drive Shafts - SOLD
• Corbeau Baja XP full suspension seats - SOLD
• Quick disconnect 5 point harnesses - $125
• Onboard CB radio and Radio -- Radio stopped working - SOLD
• Premier Power Welder -- 225 amp alternator, battery charging capability, Stick welding, 120 volt ac port for running power tools - SOLD
• First Aid kit - SOLD
• Two Fire extinguishers with quick disconnects - SOLD
• LED Light Bar - SOLD
• Two small spot LED lights - SOLD
• Rock lights
• Warn 9.5TI winch with synthetic rope / 12 volt guy double winch controller - $725
• All Grade 8 Bolts throughout
• Mostly Braided SS Lines with AN fittings
770-713-0170
o PSC Pump - SOLD
• Axles
• Detroit Locker
• Reid Knuckles
• High Steer Arms
• Fully trussed
• Detroit Locker
• Suspension
• Rock lights
