That seems a little to much on that press fit.... Rule of
jccarter1 said:
That seems a little to much on that press fit.... Rule of thumb is normally .001 per inch in diameter give or take depending on material so you might want to look into before you start and get it stuck and have to ruin it or it might go in no problem haha
pholmann said:
You can always get a little hone to take some out of the water pump if you don't have access to a lathe to take it off the fitting.
Man, wish I would've checked this thread again before I started.
Figured I'd clean it up first.
I got the works situated on the press nice an square, dabbed some dope and went at it. It was sliding right in no problem about half way and then pop!
