Jeep YJ Crawler
Vasilvasilev1
Active Member
1
YJ jeep with a Ford 347ci stroker motor, with Holley HP EFI ECU, and digital display dash. C6 transmission with manual valve body, deep aluminum tranny pan, and 2500 stall PTC torque converter. Atlas 3.0 transfer case.
Front HP Dana 60 axle, 4.56 gears with Detroit locker. Solid high steer arms, Solid 35 spline drive slugs, and RCV 4340 axle shafts. Trussed 4 link with 1 1/4" hiems(uppers and lowers), 2 1/4" aluminum links(uppers and lowers).
Rear 14 bolt with solid 13 bolt diff cover. 4.56 gears welded. Mark Williams 30 spline 300M rear axle shafts. Wide Open Design truss, 4 link with 1 1/4" heims(uppers and lowers), and 2 1/4 aluminum links(upper and lower).
Radflo 2.0 coilovers 16" front and rear, tuned by Phil at liberty mountain fab. Radflo 2" bump stops front and rear. Antirock sway bar on rear with aluminum arms. Psc dual ended ram with P-Pump.
43" Super Swamper stickies, 17x9 Racelines with aluminum bead locks.
Dual master Wilwood manual brakes, front is 1" master cylinder, and rear is a 7/8" master cylinder. Front disc brakes with dual piston ford calipers,rear 3/4 ton gm brakes.
PRP seats, five point harnesses. Two 8" wetsound tower speakers powered by a JL Audio amplifier, and a 10" wetsound subwoofer.
RCI 15gal fuel cell.
Asking price is 28,000 OBO
I'm sure there is stuff that I'm forgetting but this is the majority of it. For any other questions or info, you can call or text 404-219-4822.
this is a bad dude right here! rode with this thing all over AOP several times, it gets the job done !!
Solid build. It will hold up to the heaviest of right feet.
