beadlock width.
38x12.5" SX with a DIY beadlock on a 15x7" rim (actual measured with tire on is roughly 8 1/4" ) tires have 15 psi in them. i was bored and snapped a pic. Strictly a garage ornament right now, havent wheeled on them :haha:
I went from a aluminum 15X10 to a diy steel 15X7 (8 actual with new lip/bead)
Witha 16 inch wide swamper it made them alot more round instead of flat across the carcas.
I welded the wire in like binder said and well let me tell you that involves alot of swearing and flamable spray to get beaded up.
17" TR's are 9" wide? I just looked on thier site and it shows the 17's as being 8.5" wide. Did this recently change as my 15's are 9" wide as well.
I was making a guess... :haha:
For some reason I thought the 17's were 9.5". Im planning on ordering a set tomorrow to replace my 15's and when I looked on the site tonight, I noticed that they are 8.5's which is fine, but was curious as I see people say they are 17x9 often.
TR HD's are 8.75 from inside of the back bead(inside of the wheel lip,outside of the TIRE BEAD) to the OUTSIDE of the front bead(where the clamp ring compresses).......if you added the .375 of the clamp ring the WHEEL would be 9.125 overall width.
If you want to see tires mounted up to said wheels with 3.5" BS you could stop by my house and see mine....I also have a loose wheel with NO tire on it
You got cold :beer: ? :;
haha, I appreciate the offer tho. Im going to call Larry in the morning to place my order. Do you know if you have any red anodized rockrings in the warehouse? Also, dont forget you said you will build mine tomorrow. :awesomework:
Your set is next up in the mill......I "believe" I have red R/R's on the shelf......I'll check after break
EDIT: YES I have 17" Red R/R's in hand........haha I can hear you talking to L-bear in the other office:D
lmao....too funny. Sweet! He just told me I can pick them up anytime so it looks like I will swing by Wed around 1pm on my way home from the airport.
Thanks Jeff....I appreciate you hooking me up!
Yes they are done.....I'll box'em up tomarrow.
All I can really do for locals is put them @ the head of the line/cut list and get them their parts ASAP......I can't do anything on pricing other than emphasis bringing cash. Also we/I are available for tech problems/solutions either @ TR or via the web
Cool, looks like I might be ordering up a set of Bead-Looks as well.
See you on Wednesday....
Thanks again,
Bill
