82 Toy Build - SNYDERBUILT
Bob the bed?
  • Yes
    Votes: 106 84.1%
  • Maybe
    Votes: 6 4.8%
  • No
    Votes: 14 11.1%
  • Total voters
    126
That sucks man. I'd try mounting that tire again with LOTS of GOOD lube and then gluing the beads to salvage that tire for now while you save up for new stuff. I'd also NEVER look for new stuff. When you can save 50% or so with barely used stuff why not? :;
I'd love to be able to find some "barely used" stuff... Problem is finding what I want....
We worked on that tire for a good 45 minutes on that machine... Ripped the bead pretty good... So both sides of the beads are ripped... Doubt this one is going to hold any air...
I'll figure something out to wheel with in the meantime.. Plus try and figure out what direction I want to go with the tires.. I really dont want to get the same tire and wheel for that money... I'd rather upgrade..
You should have never dismounted the tires. Just knocked off the back bead and clean them up and bring them over.
Now that they are all dismounted I would just get the proper rims and sell those other ones.
I didn't dismount all of them... Just the one that had the torn inner bead.. I was going to flip the tire and put the torn bead on the bead lock side... Now both beads are ****ed... Atleast on this tire.
I'll figure something out. I really want to go bigger and have a double lock on here. I'm sick of worrying about inner beads.. I kick myself in the ass daily for thinking I needed 2" backspace wheels..:mad:
Maybe I'll find something at the swapmeet this year...
Well a little update on the truck. Sold my old beadlocks to a CL'er a few weeks ago and they funded most of the "new" tire and wheel purchase. I still have my Iroks and will most likely try and get them repaired and have as a set of spares or sell.
I ended up picking up the set of 38x12.5x16.5 TSL's and H1's from porter.
Hopefully in the next month or so I will be able to get myself some Pressed Centers from Mad Mac and be back on the trail.:beer:
Since I have some down time waiting for the money to be able to buy my new centers for the H1's I've torn into the front end again!
Decided to go ahead and do my 5th stud. Got most of the plate cut today and some of the holes drilled.. Not done with it as I still need to drill the knuckles, I'll work on that sometime this week. Hope I have time.
Also trying to figure out if I am going to lower the truck while I'm at it. I have the frame set at 25" right now and really like the stance.
Here is a mock-up of it with the 38's
I got a lot of crap done with the Yota today...
Got one side of the 5th stud mostly done today!!
Just need to grind down the nut and tack it up in the knuckle as well as trim the bolt down.
Lookin good Charlie :awesomework: shoot me a call when your ready to go on a shakedown of all the new stuff, Im pretty sure I got all my weak points worked out so we are ready whenever
Holy run-on sentence Batman!
It will be a while Jason. I have to get my centers for the h1s first.. Can't afford em yet.. Those shock tabs work fawking perfect you gave me!
Good deal on the shock tabs. Im probably going up this weekend to beat on it again and see if I have any more bugs to work out but Im pretty sure the Kia is ready for atleast a few good beatings now :D
Headin up Copper again?
Hoping to get my inners ordered this weekend.
Well I took my wheels down to Jason(Traildemon) here in town and he torched out the centers for me!
I also ordered up a set of pressed centers from a guy in Cali!
Well I have have one wheel/tire completely done. The other wheels are all ground down and are ready to be welded up. Need to pick up a few more valve stems before I can put them together.
