PORTER
EBP.:fawkdancesmiley:
Are you putting a cab on this?
***** :fawkdancesmiley:
If that's a true bravo suspension start preplanning for that front driveshaft. It will get super tight rather quickly, especially if you're trying to stay low.
Damn right. Plus I get to keep a tag and if I'm brave enough I can hit the streets at a whopping 45 mph:fawkdancesmiley:
Mike, Richard can get you straight on the axleshaft driveshafts as he did mine and Chris's. That is unless you got it handled.Oh ya I still remember there first car--heck I remember the very first one the gecko that dixon owned...
Motor will most likely be offset 1 inch towards drivers side, I also ran a Powermaster 9502 XS starter to give additional clearance. Getting everything to clear took a bit of time, the starter helped quite a bit also. Gave me another inch of uptravel between the driveshaft and starter allowing the motor to stay closer to center and clear everything. I didn't want to run a 2 piece driveshaft and with all the adjustments Richard made it all work.That was actually my thoughts to get ahold of richard here soon once I get my links and motor trans 100% in place.
Mike, whats the width of your chassis? I assume target wheelbase is around 108-9? Going to run a 2 piece driveshaft in the front? How wide are your axles?
Can't remember any #'s at work I have no issues going 2 piece if need be.
WB is like 106.5 and the chassis ID is like 30ish
Things are super tight on these chassis. Not a lot of room between the trans to the pinion.Why is the axleshaft driveshaft a need? Looks like you have room to fit a normal 2 piece with pillow block. Something I'm not seeing??
