BUILTnotBOT
My 2 piece front vibrates like a SOB anything past 30mph in 4wd. Rear 2wd, front drive in neutral, with front hubs locked I don't even notice it. It's the angles i'm working with for the flipped 300 to clear my clutch fork on the 4 speed.
I've debated doing the 1350 axle shaft lately as well. But isn't there still vibes with that at speed? It's an axle shaft not a driveshaft...
My front 2 piece is a 14 bolt pinion with the gear cut off and pressed onto the pillow block. Was an easy choice with a diameter of 1-3/4" no problem finding tube or weld yokes.
