So the passenger side torsion bar mount is a little more work for 2 reasons. Fist being the E-brake cable mounts to it and the second to move the lines away from it there is one bolt holding the line clamp on top of the rear crossmember that the body is kinda in the way. I was able to remove the bolt and clamp with extreme prejudice and it won't be going back in,lol.
So Once its cut off if you choose to use the e-brake ya got make a new mount. If you wanna use the stock clip to hold the cable you have to shave the steel to around 2mm. My measurements on the bracket location are 3" from center of cable to frame, 2.75" from back edge of cross member to cable holder with like a 4 degree tilt to match the mechanism.
