Anybody know of a shop that rebuilds Rockwell center sections? We use Rockwell rearends mated to 100hp electric motors on our mixers at work to drive the agitators. We have 2 that need rebuilt and everything were finding is out of state.
The last pair I built went to Top Truck Challenge with 500hp.
I believe pinion bearings are bad, but not sure, gears seem to be ok, and the other is still in use, but is growling pretty bad.I can refurb or furnish you with replacements.
Whats wrong with the ones you have?
Top loader or front loading? DIff on top of the axle or in front like a normal toyota/9"ford??
Gotcha. I only have parts and build top loaders.
The diffs you have are much more common. If good used ones are acceptable then I would look at medium duty rigs like Internationals for a replacement diff.
Otherwise I would contact Pacific Powershifts. They should take care of you. In the Tacoma/Fredrickson area.
http://powershifts.com/
https://hdtransaxle.com/
Might be able to help. I know lots of guys with oddball diffs from logging equipment use him.
Steve Manion.
He is very good & has everything you could need.
Take a Heavy wallet though as he is EXPENSIVE!
