Finally. Getting close on the buggy
Stonebone
Member
Hi everyone. I havn't been on here in years. Life took a few unexpected turns.
Finally got started in on this thing about 8 months ago.
I was hoping there may still be some guys on here communicate with on some of my questions tech related etc.
Right now I am trying to order up some of the last small items to finish the project.
I have two questions at the moment.
1. I plan on running headlights and tail lights and a backup light, but to get orv tabs do I need brake lights, and do they need to be any specific size?
2. Is it hard to get orv tabs nowadays on a homebuilt buggy?
I couldnt find much online. I have recipts for everything exept the engine. It was given to me from a friend
Well it took longer than I thought to build it but its finally done. Just waiting on my oil accumulator.
Just gotta finish a couple things with the trailer and tow rig and hopefully get to Sand Hollow by the 7th of Oct.
Havent got to wheel it yet exept a poser pic on a neighbors rock in her front yard
LMK if you have any advise on getting a VIN number stamped on it. I have spent hours onlone and everything just says no availability for inspections.
If I get cought without a VIN OR tabs does anyone know the fine?
I lost a lot of build pics from broken phones
Built 4.3 on propane. Stteering14 bolts front and rear with Crane parts 538 gears spools and hub flanges. Th 350 tranny with reverse manual valve body and a Atlas transfercase. 18 inch FOA Coils triple rate
Trail worthy double beadlocks Kryptonite 40 styckies
Its heavy at about 4700 lbs without water in the front tires
I had the chassis feom way back and recently finished it and changed a bunch of tubing to work for me Just finally started actially working on it about a year and a half ago. I almost had it built after a solid year of working on it many hours a day but the motor I had was junk so I spent the summer assembling another motor with help from my step son.
I just got it tabbed so now I gotta fix my trailer brakes and head to Sand Hollow for a shakedown run
