For Sale SOLD -- 2005 LJ, Tons & 40's, 14" ORI's, street friendly
EARLWALKER
New Member
Selling my 2005 Wrangler Unlimited (LJ) Rubicon. Stock 4.0L engine and 42RLE transmission with 93,000 miles. Virtually zero rust. Has current Missouri inspection and plates. Custom 4-link suspension front and rear with Ballistic joints. No bump steer, and very good road manners. Mickey Thompson Baja Boss 40x13.5r17 tires mounted on Raceline beadlocks are within 1/16 full tread and spare is new. 5.38 gears in Dana 60 high pinion front axle w/ 35 spline 4340 axles, Yukon Hardcore locking hubs and ARB locker with heavy duty hoses and switch . Rear 14 bolt with Yukon Grizzly locker and e-brake. Has hard doors and trail doors with soft top. PSC hyrdro assist steering. Tons of flex with 14" ORI struts front and rear, fully adjustable ride height and compression. Full roll cage, rock sliders, skid plate and 3/16" rear quarters that are color-matched bedliner. Stretched 5" front and rear, 10" total stretch for 118" wheelbase. Pro Comp LED headlights, recessed LED tail/brake/reverse lights. Poison Spyder DeFender highline flares. Tom Woods rear driveshaft w/1410 U-joint. Flex-a-lite radiator with electric fan, and external Derale transmission cooler with fan. Onboard air with Viair compressor and reservoir tank. Optima yellow top battery, Warn VR 10K winch. Build allows low center of gravity and maintains the rear seat all full stock cargo area.
Located in Greenwood, MO. Asking $33,000. Ready to go wheeling on the drive home.
