skipnrocks
I am pretty sure I know the answer to this but figured I would check with your vast experience and knowledge and separate all the crap I have read.
Heres the scoop, my pops just bought an awesome jeep based buggy on tons, it is set up with 14in fox 2.0s on all four corners.
it has a off road rear sway bar which is disconnected at the moment due to an aluminum arm (a whole other question? should I ditch the aluminum arms? 1 is stripped completely.)
It rolls pretty good under torque and will lean heavy to the right. I will for sure be hooking up the back sway bar and thinking about a front one, but is this the only way to control unloading on airs?
It will also lean pretty good when turning, it is on 40in stickies with detroits front and back, four link rear and 3 link front. geometry seems legit.
