kushKrawlin
Just so yall know, i do a ton of reading and research, and I'm generally frustrated to my limit when i ask yall for advice, it's nice to be able to ask for advice and not have someone tell me to search when im already dam frustrated.
Ok. Anyways. Heres the deal. I got my rig a year and half ago. The starter was fine at first, and started making some god awful noise.. After trying to shim, over and over i got a smaller pretty good starter from summit. It has work flawlessly for some time, started like a new car. Until recently!! Started making a bad ass grinding noise, somtimes, like it's not falling in line correctly with flywheel. When I look there are no teeth really messed up, although I did notice that the starter bendix(? The lil gear that comes out to crank and then goes back in) a lot of times is stuck out after I turn my rig off. I have read that voltage, bad ground, or being out of the line could be the culprit. Im at my wits end i'm to figure this out. Figured some of you guys had a lot more experience the starters. This **** cannot be this hard. And advice would be awesome. Most of the time when you push the button to crank it, it will make that awful grinding noise, so I will stop for a split second and push the button again and it always works good. WTF? That's why I believe it has something to do with the mesh of gears. But Obviously I suck. I will get a picture shortly if it helps. This sucks. In case anyone is wondering is not the coolest sound in the world. It is definitely a head turning sound tho. Haha thanks fellas
