Rockwell HELP?
Eddyj
Birmingham
I just welded up my spider gears when I was reassembling it one side says bevel side. which side is that?
:dunno:
AdamF said:
Did you get this figured out? I have 3 chunks laying on the floor and can get a picture if you need it.
So are you saying your bull gears have that, too?
I remember when I was putting one of mine together I forgot which way in went back in. I never noticed anything like that on the side so I tried it both ways. It seemed to set up the same both ways so I just went with the second setup I did. Hasn't seemed to matter if I did get it wrong.
I could not see a difference either way. I put it back together with that side of the gear on the side facing the pinion. Seems to be fine. :dunno:
I've taken a bunch of bunch of rock chunks apart and never noticed it either , I've always just centered them back up with the spur gear and ran em, never had a problem but :dunno:
