sway-a-way air shock parts?
scrowexj
Danville, Alabama
Where can you / is the best place to buy sway away 2.0 air shock parts? I bought a set of shocks from a guy that supposedly 1 needed seals and all else was good, well they came in the mail and one of the shafts has some deep gouges in it and will have to be replaced. so now im looking for parts any help on where to buy would be appreciated thumb.gif
I have used poly performance and e-shocks.com. If you know the exact part numbers that you need I would go with e-shocks. Cheaper price and I got the parts the next day. If you need help figuring our what part numbers you are going to need just order from poly performance. Its worth paying to extra to get the right part the first time.
Awesome, I'll send you a PM need a price on a 12" 2.0 because I got shafted and everything is screwed in the one shock not fixable with out everything new
Here are some pictures, only one I ain't got is inside the outer tube, and it's scared up bad to, the spring is also bent out of shape it's hard to tell by the picture though
More
More
