Random Thoughts
Re: Random Thoughts
onepieceatatime said:
Pretty typical for Ohio State Fans. Had a shitty year and don't understand why they had to play for a participation trophy.
Haven't watched a game this year and really don't care much anymore but I was referring to bama fans bitching about the quarterback but winning 24-6
Re: Random Thoughts
tonybolton said:
Jealousy is a stinky cologne on you, Sir.
Typical rich folk picking on us poor struggling hard working people
Re: Random Thoughts
This weather makes picking up and delivering construction equipment a real chore. Glad I get paid by the hour as I sit here waiting on a service tech to come jump start a roller for me.
Re: Random Thoughts
1tonrenegade said:
You missed a good day saturday
I woulda made it miserable for you then....whin'in and cryin' and all the runs to the Dollar General to pick me up some tampons. ;)
I knew this week was gonna be bone jarring cold, so that left me with 1 day(Saturday) to try and work on a Ford to make it fast. Luckily...I finished with only a few hiccups in the tune that need ironed out.
Re: Random Thoughts
tonybolton said:
I was told to pick on someone like me.....so I did. (((lets see what direction you go with this :) )))))
Well I see what ur trying to do here and I will have to say no thanks I'm not gay but I appreciate ur interest Thank you
Re: Random Thoughts
tonybolton said:
Well played....I don't care that you're Hill-dawg voter, you're good people.
Do you like the pro-charger? My wife has a 16 GT, been wanting to do some stuff to it.
Re: Random Thoughts
Lmao. I'm no hilterbeast fan
Re: Random Thoughts
Honestly, it has some quality parts, but the pipe routing / connection leaves ALOT to be desired if you're looking for a "factory look". There is just simply no room to run that piping from the blower to the front of the car and not look "janky". Also, the front pipes that 90 degree around to the intercooler hang lower than I thought.
I'd get the kit again, but if you want a factory look, I'd go with the VMP / Whipple / Roush style. The only issue with those is the low end torque they make. If you're just going to run street tires, the low end torque is useless(to me anyways).
Car drives like normal below 4krpms then freight trains from there to 7k. I commend the engineers of the kit, they did the best with the areas they had to work with. I think if they could've used like maybe some oval piping it would better.
Also, you have to mount the blower to the bracket and install it ALL at one time. Pretty nerve wracking trying to start a 12mm bolt in some aluminum while suspending that 50lb chunk with one hand while trying to feel if you're cross threading that bolt or not by hand.
Re: Random Thoughts
Man I seen that one coming a mile away. Rookie
And I bet ya got some raisins riding high and tight with this cold weather so no support needed
Re: Random Thoughts
After workin' on the car outside Saturday....I had to hook the winch up on the jeep to pull that little guy outta hibernation!!!! LMAO!!!
Was pretty cold...I could only see 7 inches of it!
Re: Random Thoughts
The only real problem I see with that Procharger kit is the way the air filter is mounted. I had a Magnum SRT8 with a D1SC kit on it and the air filter laid right over the driver's side valve cover and header, pretty much just like it does on yours. After doing any stop and go driving in any weather it becomes heat soaked really bad and will feel way down on power.
