fuel cells for a jeep??????
tennessee_4x4_man
can any one tell me what size fuel cells people use that fits behind rear jeep seat like in pict
Unless they have fixed the issues with the RCI , they crack at the seems. I think MotoBuilt is someone is building a similar tank.
Check out the RCI 2161J cell. Similar dimensions to the aluminum one that cracks, but a steel/poly bladder cell
I had one built to fit and uses factory fuel pump...ir holds 16 gal....same cost as RCI and has never busted at the seams.
A fab shop should be able to build one reasonable
