I found a small slit in my tire next to the ring. I thought about trying to clean it up and pack cold vulcanizing in there or maybe bead glue. Anything else? Can't justify buying a set of tires just for this, mine are just getting broke in.
Thanks, I may get some of that. I have the stuff they use to install windshields with. It looks to be similar.Blk 5200
Thanks10-4 .i used 5200 to seal the bead on some tires I got from a buddy he used screws and ripped them out a couple time I smoothed the bead and went put down a bead of 5200 an filled it .I would take 6 months to leak. 5200 is some bad stuff
