Jeep tj flipped Dana 300
97cummins
I've searched and can't really find what I'm looking for. So with that being said does anybody got picture of flipped Dana 300 shifter set up for Jeep tj trying to see how been setting them up under the body.
thanks
Justin
Check out JB Custom Fabrication. I have mine flipped and mated to a 231. I use the triple shift to control the set up but I get some pretty serious leaking coming from somewhere around the shifter rails due to the flip.
I will get some more when I install. I got couple more things to do and will get more pics before I install.
This may end up being on me to do list. Im tired of the nonstop leaks from those shifter rods.
Easy to set up and put together. Only sells with the straight shifters if you got a tj I got ordered shifter handles from advance adapters. Hopefully installing in a week or so
