MIG'DHORSE said:badass. good luck with your driveline angles:flipoff: ... and especially your front driveshaft. gotta get tha 2 piece!
now drop in a racing engine with high hp low torque capable of 12000 rpm. the gears will give you all the torque you need. the rpm will give you the option of slow. but imagine the unstoppable power of 512:1 ratio at like... 9800 rpm's at like 400 hp! DO IT! :cheer: :cheer: :cheer:
actually... get a Formula One engine.. a 2.4l v8 tuned to the capability of revving up to 21k rpms. Barely any torque, but lots of it at 512:1! you could drive down the freeway in 4lololo!
JOOP said:nice low crawl ratio, but how slow do you need to go on 33"s :flipoff:
421 said:33 Thornbirds! I got from you, cause you bought a new set of them.:haha:
Fair enough. :haha:421 said:I couldn't afford a parking brake.:super:
thanks for the info dosent really matter ill rarely use it back case is a 23 spline noing me ill brake it in 2 days anyway:corn:crash said:I am 316:1 and I hardly use it. only place is over at the moon rocks and down at the hammerz.
I have found once you get below 200:1 it really doesn't matter and at 510:1 you will certainly wana be careful as the torque multiplication will be crazy high....
Hmmm. Birf or output shaft, which is it gonna be....:corn:421 said:thanks for the info dosent really matter ill rarely use it back case is a 23 spline noing me ill brake it in 2 days anyway:corn:
how about motor:flipoff:skrause said:Hmmm. Birf or output shaft, which is it gonna be....:corn:
