Anyone have one of these? I bought one barely used for my daughter. The tires still have the knobbies on them. But anyways. It has a very weak idle. Only likes to run with the choke on.
Now I'm not much of a carb guy but this thing looks like it only has 1 air/fuel mixture. I think I might have it set correctly. Checked the spark plug and cleaned it.But it still doesn't like to run. Also I think I might have fried my battery. The battery only has 11.65 volts. I didn't charge this one correctly and I didn't set it up correctly. I poured the acid in and started charging immediately. Now I see after reading the owners manual that your suppose to let it set for an hour first. . My charger only has 2amp for the lowest setting. This battery is suppose to be charged at 1.5 amps for 2 hours. So I bought a new and am only going to charge it for an hour at 2amp. Hope it works.
I've been trying to find a forum or owners manual for it too.
