14 bolt disk brake ?
roll over dave
gardendale
I bought the weld on kit from bluetorch they say run 73-87 rotor I've called napa and advanced they say they don't sell just a rotor they sell a hub assembly need to know what rotors y'all guys are using thanks
I have purchased the rotor from Advance Auto Parts and from Auto Zone. They do sell just the rotor, I do not remember the exact part number. Sorry :dunno:
Are you telling them it's for a 4x4, the 2wd is a hub and rotor all in one. I bought 4 at one time for my buggy and didn't have any trouble.
My brackets are the bolt-in's from Great Lakes Off-Road...I used a front rotor and caliper for a 1977 K20 (3/4 ton) 4x4, most of the kits use the same setup.
O yeah your probably going to need longer wheel studs. Not sure of the length, but just knock one out and take it to the store.
roll over dave said:
I said 2 wheel the damn aoto parts stores if it ain't I'm a computer they turn into retards I appreciate it fellows I'll find sum
Well, you gotta tell them the correct application.... :dunno:
Unless the parts counter guy knows what your custom brackets require...,
That said, I like the 2wd (C20) brake lines. They have a nice little bracket built in that is handy to mount to the axle tube.
HEY MAN I USED BOLT ON BRACKETS FROM ruff stuff AND GOT ROTORS FOR 74 3/4 4X4 NO PROBLEMS AND IM STILL RUNNING STOCK STUDS BUT LONGER ONES WOULDNT HURT DEPENDS ON WHEEL APPLICATION I GUESS ..... :****: :dblthumb: booyang booyang C-YA ON THE TRAILS ...
