14 Bolt front axle. 3 1/2in X 1/2in. wall, Dom tubing for axle tubes, 67 1/2in. WMS. Has solid axle inner C's. Is not welded all the way around the inner C if pinion angle needs to be changed. Pinion angle is 10 deg. caster angle is 7 deg. Has open carrier, 3:73 gear ratio, bearing caps, pinion housing, and stock yoke. location in Blue Ridge GA asking $1,200 OBO. If interested call 706-838-4640. Ask for Brian. No calls after 9pm please.
