Thanks for your help RustyC. For whatever reason, I was thinking that the spindles were already slugged from the factory and I could cut a weld and then beat them out! And like you described, there was a fusion weld right about where you pointed. Now I have to figure out how to weld in the slug and spindle that I received from EOR. I have Plowboy's old axle housings and I am removing the rear spindles to place on a new housing. The way things were welded together previously doesn't make much sense to me from a strength point of view, but then again, I never seen him have a rear spindle fall off.
