1st gen toyota ignition testing
kmcminn
I'm not much of a welder but I'm a hell of a grind
Toyota quit wanting to crank, starter is good, battery is charged. Everything is tight well I was thinking it may be the ignition switch cause none of the gauges are working or any accesories.
Anyone know where to ohm this thing at to see if it is good?
Thanks
What part of North Alabama are you in... if its close to Russellville and you come by oreilly tomorrow I will find it.
Sent from my SCH-I605 using Tapatalk 4
Edit- found it
But it being IDI line code itll probably have to be ordered, or at least OReilly in rville doesnt stock much import direct
http://m.oreillyauto.com/mt/www.oreillyauto.com/site/c/detail/IDI0/180917/02018.oap?year=1983&make=Toyota&model=Pickup&vi=1277232&ck=Search_ignition+starter+switch_1277232_933&keyword=ignition+starter+switch
Is this not it? Its 6 wire 3 stacked 2
Where does it get messed up? Does the plug with 4 wires come or is there two sets of 6 wire? I'll look around at my store tonight and let you know if I have any luck
