Jcampbell54
- Joined
- May 10, 2013
- Messages
- 548
- Reaction score
- 0
Ok guys here's my Problem. 22r engine, was rebuilt about a year ago with LC Engineering kit. Started getting a lot of blow by through pcv and valve cover breather last week. Actually ran better than it ever has believe it or not. Ran compression test. #1-90lbs #2-4 120lbs. Plugs are clean, no oil use, and no smoke from exhaust. Now if it does require a rebuild would you replace main and rod bearings again or just check and reinstall new rings? Also any ideas what else it could be?
Sent from the mans IPhone.
