22re fuel pump
Plastic cell, use an E2000 with a pre-filter and post filter. My preference is no foam but thats because I had foam in my last one and it broke down and was a pain in the ass to rid the whole fuel system of it all.
Like Al1tonyota said, if you pony up for an aluminum cell then you can make that stock sending unit work. Use the rubber seal to help trace a template, cut holes, drill/tap where needed, install the sending unit and roll out.
you can use self tapping coarse thread screws in a plastic cell also, works just fine.
