truck-oholic
- Joined
- Dec 22, 2013
- Messages
- 460
These are the heavier duty 24 bolt "paired" hummer wheels. The wheels are stock right now except for the addition of rock rings being welded on. The original centers have not been cut out yet and the 8x6.5 pressed centers have not been welded in so you still have plenty of options of bolt pattern and backspacing. I will only separate pressed centers from wheels if wheels are sold first. Rubber runflats go with the wheels. If you don't want them because you will be running PVC inserts, price is still the same.
Price is $650 cash firm for everything or I will split up as follows:
H1 wheels with 1/4" thick rock rings, rubber runflats, and 45 degree valve stem adapters - $425
8x6.5 bolt pattern 1/4" thick pressed centers for 3.5" backspacing - $225
For comparison, here is pricing for all of this from Trailworthy Fab:
24 bolt paired H1 wheels - 4 @ $95 = $380
24 bolt paired rock rings - 4 @ $42 = $168
8x6.5 pressed centers - 4 @ $65 = $260
Rubber runflats - 4 @ $10 = $40
45 degree valve stem adapters - 4 @ $4.50 = 18
Shipping - $175
Total - $1041
Location is Spring Hill, TN 37174
Thanks,
Jesse
610 999 1546
Shipping - $175
Total - $1041
Thanks,
Jesse
610 999 1546
