2x2 square trusses
Eric04
MICHIGAN
For some reason i cant search on my phone through tapatalk
Doing one for a 14 and possibly the front 60
Lets see what you guys came up with.Its a straight forward deal and i have some ideas for mine
:dblthumb:
Some I did
kmcminn said:
Yankster, is tube tubing welded to the center section. I'm guess they are. Just been think about doing ones like yours instead of the Artec.
No, not welded to the center section. Only welded to the tubes.
Big Block tube buggy said:
locktite??? :dunno:
I guess you could use Loctite, but those are welded. The housing is cast steel, not cast metal or cast iron like a black cooking pot. Just heat it up a little, do not get it red hot and weld it with a mig welder.
Brad's will work. But the ones not tied in to the center. What keeps the center from spinning on the tubes? :dunno:
Do you remember the thread and pitch of the bolts? I like that idea. I'm looking for something simple to mount links/steering on my Chevy and most trusses are $$$ and weigh a ton. I'm trying to keep the Zuk as light as possible.
Sorry, I do not
