3/4 elliptic spring Q
heep70
Unsociable A--hole
Bonney Lake
What is a good spring (2.25" wide main leaf) to use for the half spring on the rear of a Toyota?
A commonly used mainspring is a factory YJ leaf mainspring. They can be bought for cheap (as takeoffs), are 2.5 wide, relatively flat, and in general are the common ones I've seen used
T.
what about f-350 springs..I thought they were the hot ticket. well they were 5 years ago anyway.
toyota rear main leaf is the way to go
i have also used toyota front main leaf they worked ok
TreeClimber said:
A commonly used mainspring is a factory YJ leaf mainspring. They can be bought for cheap (as takeoffs), are 2.5 wide, relatively flat, and in general are the common ones I've seen used.
heep70 said:
What about wrangler main leafs? They are 2.5" wide also right?
:rolleyes:
lol.. yotadudes....
heheh..
j/k
actually, I can't really contribute intelligently as to what a yota would best use for an ellip setup like the one you are going for, but 2.5" springs from YJ's/XJ's seems to be the way a lot of people go.
