4.70 gears
A little time consuming, a little machine or grinding work..............I'll do the entire setup if you bring me the case and parts for, $100.00.
lilyota said:
Is it a pian in the a$$ to install the 4.70 gears in the toy transfer case
I would say the 2 most important things are the proper sized punch(to remove roll pins), And a good press.. Going to odie is a good idea as im sure hes done a few and is comfy doing the work..
probably the hardest thing to do is press off one of the bearings if you dont have a press. i was able to do it with a vice and hammer ( i dont know how it worked). other then that its not bad, just takes a little time.
