4runner lift/ driveline length
Dubshot
Puyallup
How much lift can be put on a 85 runner without any problems without the driveline slipping out? I have a set of shackles thats suppose to either be 2" long or 2" of more lift.. I think i have a set of 3" and 4" springs. Is the shackle a bad idea even?
i wouldn't think the shackle are a bad idea. better then a gay body lift. If the shackles are about 9inch long they are a 2 inch lift... If you put more the 4 inches of lift i think you will have to mod your d line but i think it depends on the length of you d line now and if it a two piece or one.
i wouldn't think the shackle are a bad idea. better then a gay body lift. If the shackles are about 6 1/2"inch long they are a 2 inch lift... If you put more the 4 inches of lift i think you will have to mod your d line but i think it depends on the length of you d line now and if it a two piece or one.
Fixed it for ya. Stock is 3.5"
But yes you can usually get away with 3-4" of lift befor DL and Pinion angle need to be tweaked/lengthened.
Yeah 3" superlift springs and 2" shackle lift in the front is way too much for the driveline length.. I can see the splines and there is alot fo slop side to side play.. The axle was at full drop on both sides just hanging basically so if it articulates and the passenger side drops even more the driveline will probably slip right out.. So I am not messing around with this silly stage 1 stage 2 stuff and I am just going to mount rears up front and my chevys in the rear.. I will have a square driveline made since I still weld like crap but I am thinking I will try to get my duals at the same time. Any questions, comments, concerns, or advice?? This is my first real build so Im trying to build as I wheel and get money..
My 85 straight axel has 4" springs and 2 3/4" shacles and I just did the front drive line( 3" added). Back is stock and works fine.
Well I plan to put dual trasfer cases and rears up front so I want to try and get both of those done at the same time so I can have my driveline made one time..
