6.0 issues
skipnrocks
Billings Montana
We have a heating and starting issue for a six point out. The camera has been upgraded the tuning wiring was done by Jim's performance. Motor consistently runs it to the 25 to 30 and less you're climbing and it will run 240. The motor always back fires the first couple times you start it and then runs pretty good after that. It seems like it might be running a little bit lien? Which could be part of the problem. In addition we have backfilled the incision with Cunen according to GM's instructions. Drilled a hole in the thermostat. And the Steamport are hooked up to the radiator.
Or fuel delivery is using all the factory set up so we have a line runs to the motor and Line that runs back to the fuel pump.
