I haven't heard anyone say that sixties big blocks ran better than today's. That's dumb to think that fifty year old technology is equal to today's. That said, Any internal combustion engine is nothing more than a pump, 454 cubic inches will only pump in and out so many cubic feet of air at a given rpm (normally aspirated) even given better BSFC and intake Mach number, there is a limit called peak volumetric efficiency. Therefore, exhaust diameter and length has the basically same effect on a "68 Hemi or a 427 LSX. Just because you liked the way your buddy's engine sounded to you with 3" exhaust rather than 2.5" has absolutely no bearing on performance. Before you pull your **** out and step on it again, I've been building engines for 50 years and have made the effort to educate myself on what makes them work. Wizzo, Like I said, don't believe everything you read on the web, any of the aftermarket exhaust manufacturers will be glad to tell anyone what will work best on a particular combination based on mathematical calculations and actual dyno results. They're called engineers for a reason.
