6.2 diesel coversion to 5.7 gasser???
Brian H
How hard is this going to be? Will the 6.2 Fly wheel work on the 5.7?
i dont think it will work...the flywheel that is... kennyw did the swap the other way on a truck he would be the one to ask
Now your exhaust will be different, as well all the backets I don't believe will swap. The BH pattern in the same, and I believe motor mounts are the same.
Are you sure its a bottem end noise and not a bad injector? I have had them make a loud knock due to an injector issue...
Again...its a 6.2.... not going to look that far into it to see if its a bad injector. Gas is cheaper.:redneck:
From a professional point of view--you are better off either fixing it--or getting another rig...
0 Words
