7.3 IDI horse power adders
  • Thread starter Thread starter lowbudgetjunk
  • Start date Start date
L
lowbudgetjunk
Guest
No I don't want a turbo, soup bowl only adds noise, dual exhaust is in the works ( but discussion is appreciated), camshaft?
I fully know I am not getting 300 hp and 500 ft pounds out of this engine. If I could squeak out 20-30 more without costing an arm and a leg, I would consider it perfect. All the mods need to keep longevity of engine in mind.
Timing. Add timing. I had one in a work pickup that would get 18 mpg and only get 20k miles out of rear tires. in think you can rotate the injector pump.
Not exactly a power adder but auto or manual? I had a bone stock manual that would walk off and leave an auto Idi with a turned up pump. That was the only thing it would walk off and leave though. :rolf: God I miss that truck.
This one is an auto. I am not looking to win any races, but do want those elusive 30 ponies.
Sent from my LGL62VL using Tapatalk
I do and now I have obtained another project to finish up another project.
I'd reconsider the turbo n turn up the pump.... Best, easiest, and cheapest way to wake up a n/a diesel.
More air plus more fuel equals more power.
So the cam threads are garbage? How about the difference opening up the exhaust? Worth the time or worthless as well?
Matt Maier makes over 1000hp with his power stroke and I believe it still has a stock cam. But I realize the PS is a different monster. Fuel and timing will cost you nothing but a little time. Not sure how a cam would work out, I have not heard of anyone trying that on the 7.3
Sent from my S50c using Tapatalk
Changing cam is IMHO a losing battle... The engine bore to stroke ratio of the engine likes a certain power band... Changing that will likely be very disappointing...
Plus a used banks "factory" turbo setup for that engine can probably be had for a fair bit less than a custom cam..
Force feed it and forget the little tricks... Not needed
I put a turbo on an 89' stick 350 and bought a 94' factory turbo 7.3 auto and neither would do more that 5 lbs. Boost. Now if you would do the timing, turbo and could get it some more fuel, you might get some where.
