700r4 to np203...
Boonie Buster
Stuck on a Curb
Your Mom's
So apparently there are two methods to this..
I currently have a 700r4 mated to a np231 (was mated to a np207 before). And am now thinking of taking the dual cases from the LUV project and putting them in the s-10. the cases are a np203/np205 mated behind a th350. I dont know much about the th350 it is mated to, but i know that i just had my 700r4 rebuild a little to replace some broken/worn gears/clutches.
Supposedly the tailshaft on a 700r4 is approx. 2" longer than that of a th350 requiring either a 2" spacer or a new tailshaft, I am thinking for the price a new tailshaft would be my best bet.
1. get a 2" spacer and bolt it on, not sure of the price or availability (can't find anything on it...)
2. get a new tailshaft for the 700r4. $172 from A.A.
Below is a link to what i think is the right tailshaft for the job...
So is this the correct tailshaft i need to do this swap???
https://eshop.advanceadapters.com/c...-gm-np205-adapter-kit-28r-50-6900-50-6900.htm
Anyone ever done this or had any problems with it, someone was saying the 203 is too heavy for the 700r4 case and will break it, I don't understand how it could break it, unless support imporperly...:eeek:
Any suggestions? I have thought of getting the th400, but i am not sure of it's O.D. whether or not it would allow streetability like the 700r4. I have also thought of having my 700r4 build a little more hardcore or buying one built also, those are a couple other options, I just hate to have to sheel out more money for it after i just dumped money into it for repairs...
well the adapter would be simpler and cheaper but i would not advise doing that at all. I don't know anyone who has ever run a doubler behind a 700r4 but then I would never do that or even run a 700 in a wheeler.
if you do this you need to build extra supports and basicly run a second crossmember, the weight of the doubler will cause the end of the tranny crack and eventually break I did and have seen a couple other people do it with even a th400 which is way beefier than a th350 or 700r4.
are you trying to install the tailshaft yourself?
I, personally, would just retrofit an iron-case manual up in there and not worry about all this shizzle :awesomework:
:stirpot:
I hae a transmission guy to do the trans. work, I am still not understanding how the weight of the t-case is going to break the transmission ( I am going to have the t-case and tranny properly supported for torque and weight) so how is it going to break other than utter self destruction....
And yes, I too have seen this setup ran behind a th400, I would almost rather run it behind a th400 if I knew that it would have the same O.D. as the 700r4 but i don't (haven't researched it fully yet) so....ya... i dunno what i am gonna do....:mad:
I was told by a chevy parts guy there is a factory spacer available to retrofit the 700r4 where a th350 used to live. Supposed to be cheap too, google is your friend.
With you staying with 4.56 and going to a 42" tire, do you really need overdrive....? :flipoff:
Can you divorce them? You have the length, and can probably source a d-shaft from a shorter rig to run behind it all.
A & Reds Transmission Parts
2501 E Truman Road
Kansas City, MO 64127
(816) 483-7337
The part # 7Q35A and it sells for around $50.00. Trim about 1/8" off the end of the 700r4's output shaft and from there its all bolt-up.
Like I said, google is your friend
2501 E Truman Road
(816) 483-7337
So this is just a spacer that goes on the back of the tranny and keeps the same bolt pattern to the front of the stock tranny to t-case adapter, correct? not sure if i said that right, but it is the same 4 bolt pattern on either side of the spacer...as on the back of the tranny...correct...?
