ROOKIE
camano island
would these batteries work for my crawler and what volt should i go?
thank you have a good day:awesomework:
whoops my bad for got to push the paste button :haha:
2/3A Size Rechargeable Battery 1000mAh NiMH 1.2V Flat Top Cell
these batteries :haha:
most saddle packs use a 1500 mAh cell. The standard stick packs you see for sale at most hobby shops will be 3000 mAh IIRC.
just fyi, the mAh is the capactiy so increasing your mAh will let you run longer. The voltage (each cell is 1.2v) will increase your 'power' providing higher wheelspeed, so the more cells the higher voltage you'll get.
thats a reall watered down explanation. check out cheapbatterypacks.com for more info, thats a good place to order battery packs from.
Go to cheapbatterypacks.com and order the 2/3a 1500 packs. They are not expensive at all. You can get a 7 cell pack built sent to you for around $25. Go for the 16 ga. wire too.
i just bough 2 saddle packs already built for like 48 buck 7 cells also bought a new ax10 body :awesomework: :cheer:
